XS Power
I wouldn't know but you should post what yoiu have and your set up so they know the voltage coming out and how many batterys you will need ect. If your running a 200 watt system it will be dif then if your running a 2000w system, post your setup.
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
do you guys know if my d3400 will fit up front in a mazda3 2006 hatchback? I already own a d3400 and a d3100 and Im hoping I can use the d3400 upfront cause I may go buy that car today :D
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
i have a 73 impala Havent got alt. or batteries yet heard alot about mechman alts and xspower batteries. I already have 2 rf T2 d4 15s a t2500-1bd + 2 t600-4s + 6 t1 6x9s + 10 t1 6 1/2s and stinger 0gauge wire for big 3 and amps. Which alternator and which battery or batteries. Not really for comp. just something to pull out and show off every now and then. Thanks for help.
i have a rf T2500-1bd and 2 t600-4s which battery or batteries should i use?
A few D3100s should work fine for you.:good:
Had a guy that fit a D2400 in the stock location, so you probably can.
3400 under the hood and 3100 in the back if you are going to be doing demos and running the V belt on your alt.
Not as long as what the stock size would take, it fits good :D Im so happy!
Pioneer 4300DVD
if you did that then you should be able to get a strong enough alt to only use one battery upfront and you can probably fit a larger battery than the D3400. I would just measure how much room you have to work with and then put the biggest one in you can fit.
  • Who's Online   0 Members, 0 Anonymous, 1117 Guests (See full list)
