amp questions
woodzyspl
ok igot soundstream xxx15, guy i got it off had another 2, guy who got them said they all resting about 1.8ohm, so my wire options are (i think if im right 1.8 .46? and like 3)
so would the T2500 bdCP take .46 for burps? or best run it at 1.8..
id prefer run 2 (1 amp for 2 coils :) )
or should i get a dc 9k :drink40: and blow dat bitchh
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
annnddd a BUMP :drink40:
AMP: dc 9k @ 18v
Rockford wouldnt recomend running that low so it would be your own risk. And you will need badass electrical to run that low. I think 2 (one per coil) is a better option. Im doing a build soon with 2 bdcps on per coil. The dc9k is another good option as well.
Rebuild Log with the SMD
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
99 Lexus RX 300 (sold)
ADDING
Honda - Hertz setup, more to come
Porsche - Fi BL, XS Power, more to come
coming soon..
peep the old rebuild log of the Lexus RX
i think if i run one per pair of coils would be to high of an ohms, or way to low..
but im sure the 9k would do fine at 1.8 (or there abouts) and sound decent..just need ask if it can be wired low for a lil burp..
AMP: dc 9k @ 18v
If you coils read 1.8 ohms on a meter then that should be a nominal 2 ohm load. 1 ohm and 4 ohm nominal wiring options.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
1 per coil and 1 per pair of coils are two different setups, you gotta be more specific.
CURRENT..
Honda Accord Coupe
Porsche Cayenne S
Lexus CT200
Lexus ES300 (sold)
ADDING
coming soon..
  • Who's Online   0 Members, 0 Anonymous, 611 Guests (See full list)
