IH8PunkRok Posted October 14, 2007 Report Posted October 14, 2007 http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=1 use the top one Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
KWP369 Posted October 14, 2007 Author Report Posted October 14, 2007 in paralellamp + to sub1 + then to sub2+ amp - to sub1- then to sub2- so i'll have 2 wires runnin out of the positive output from the amp 1 to each sub, and 2 wires runnin out of the negative output from the amp 1 to each sub? Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
IH8PunkRok Posted October 14, 2007 Report Posted October 14, 2007 (edited) or u can have another wire from the positive terminal of sub1 if wanted to but yes two wires for positive and negative Edited October 14, 2007 by IH8PunkRok Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
KWP369 Posted October 14, 2007 Author Report Posted October 14, 2007 http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=1use the top one i see, thank you all for the help i really appreciate that i haven't been flammed at all yet, but i'm still keepin my options open any other amps out there that u ppl recommend Quote Do you read ur own response b4 you post?...or just type ur gut reaction and headbutt the enter key? How bout this, the Caddy sounds so damn good it can put a smile on a "deaf mans" face mat then mix hardener into resin and soak mat. beeeeeyaw glassing for n00bs
IH8PunkRok Posted October 14, 2007 Report Posted October 14, 2007 np that amp though is one of the only ones i could find that did 1000w @ 2 ohms there is a rockford fosgate t1500-1bd that does 1000@ 2 ohms but its really expensive http://sonicelectronix.com/item_8955_Rockf...+T1500-1bd.html see? Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
Derrick824 Posted October 14, 2007 Report Posted October 14, 2007 Rockford Fosgate T3002 for $142 shipped This amp is sverely under-rated and good for around 900watts which is plenty of power for those audiobahns. http://cgi.ebay.com/Rockford-Fosgate-Power...1QQcmdZViewItem Quote
