Why Higher Voltage?
Ok well i got my first car in the beging of the year, but didnt put the system in till spring. I installed a stinger voltage gauge about a month ago. For the first three weeks i would start the car and it would read 14- 14.1. After about ten mintues of driving it would read 13.2 -13.8 depending on if i was stoped or bumping. Ok so now in the past week it had been getting colder, espeacialy today. I go start my car and it says 14.3 , its never been that high. After about 30 minutes of driving it sill only dropped to about 13.8-14 votls. Why is this? I know higher voltage ois better buy why is the temperature affecting my voltage. Can my battery be going? Right now i have stock alt and battery. I have a HC800 that im going to but in soon along with a yellow top under the hood.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
1998 Cadillac Catera
SPLMAX CUP 2008 Fourth Place Overall
Lower temperatures also increase the cranking amps produced by the battery
if thats the case would it be legal to surround your batts with ice when doing comps? it would be interesting if they allowed that.
Need any thing chromed? Hit me up!!!
gamer tag: (360)
mEmEnToMoRi64
My Myspace
refs:
from here: RollinSoLow, Derrick824, Ray
from c.a.c.o. : teamsubgopoof, splvictim20, SundownAudioNY
from C.A.J. : Donpisto, spladdict19, CAJunkyard, JBLCAMRY, DasBot (robot underground)
from ca.com: alxmlr789,photocrazy8
Heat is wasted energy. The cooler you keep your alternator (and amplifiers) the more power they put out.
This is incorrect. The colder the battery the lower your cranking amps. Every starting battery will have a CA (cranking Amp) rating and a CCA (Cold Cranking Amp) rating.
There are already competitors that use a/c systems to keep their setup cool.
Thanks for the reply man i never though of it liek that. I always hear of people having dead batterys int he winter so i though maybe cold was bad for them.
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
correct. Cold = bad for batteries.
But good for alts? Thats my i get a higher voltage?
TEAM SUNDOWN
4 Nightshade 15"s
2 Sundown SAZ-4500
8 Deep Cycle batts
my system knocks in the summer but in the winter it's even crazier cause i see voltages of up to 14.6
2-DC 15XLM2 D.7s
1-DC 5K amp
Audiocontrol 3.1.
  • Who's Online   0 Members, 0 Anonymous, 4925 Guests (See full list)
