im running a pair of type Rs on 1200rms. due to space limitations, one of these alignments seems like it would work best for my car, but i have no clue how they would end up sounding. throw me some "IMO"s!
will either of these cause a cancellation? or a gain?
1999 Monte Carlo
Sony CDX-GT34w
2 Alpine Type R 12"s in 4 cubes tuned to 35hz
American Bass VFL 80.1 amp @ 1 ohm (probably doing between 1000 and 1300rms)
Stock alt, Stock batt, Big 3 Upgrade
Boston s55- 5 1/4s (doors)
Boston s95- 6x9s (rear deck)
From what I have seen (heard) Rear / Rear is the best configuration for most Trunk based ported setups; unless you are going to be setting up a trunk wall and sealing the trunk from the cabin. I just did a design for Rear facing subs with the port going through the center armrest slot and the builder said he really likes the performance of the enclosure.
But, he is trying to seal as much as he can....
Edited by PandorasCustoms
Chris - "The Apprentice" - Pandora's Box Customs
1994 Ford Explorer - "Midnight" - 4.0L SOHC
SoundStream PCX-1000D & Kicker S12L5
i wont have enough on the rear of the box to fit 2 subs and an 8 inch port
1999 Monte Carlo
Sony CDX-GT34w
What are the woofer sizes and the Xmaxx? Because it sounds like you are going with an Aero port. Have you considered a slot setup?
the woofers are 12"s and the xmax is 20mm i believe. i've done dozens of slot port builds in my days. just talked to a guy from TNESPL yesterday and he said hes gonna build me the 8" flared port for a STUPID good price. im just weighing all of my options right now. its starting to look like my best option is subs back port side...
1999 Monte Carlo
Sony CDX-GT34w
How big is the trunk? Because if you have 34" (w) x 15" (H) faceplate, you should be able to squeeze them all on the same side...
What will be the diameter of the flare?
the most i can do wide is 32, and the highest i can go is 14.5 (with the box being 24d)
1999 Monte Carlo
Sony CDX-GT34w
oh and no idea how big the flare is gonna be
1999 Monte Carlo
Sony CDX-GT34w
Yeah, that does make it a tight fit. You may need to end up with Front Subs and Side Port....
do you think there will be much of a loss with the port to the side?
1999 Monte Carlo
Sony CDX-GT34w
