1st wire, neg on battery to a bolt with clean metal under the hood
2nd wire, engine to another bolt with clean metal
3rd wire, pos on battery to alternator
now on the wire on the alternator U can run a fuse, IMO i never do but its fine to do it either way. with fuse its just the safer way
So if the engine wire is currently going to the battery.. you can disconnect it and ground the engine wire to any good ground location? It does have to be the battery? I dont get how that helps the Amp flow, im confused :(
Ive seen a few different threads saying that where you ground it (battery or chassis) doesn't really make a big difference. I was just confused where my engine ground was at! But I guess I'll just make it wherever I want haha, the shortest run possible because 1/0 ain't cheap!
so far...
HU- pioneer DEH-P59001B
Amp- crescendo BC2000D
Wire- 1/0 awg welding lead
Electric- Big 3 ^same wire
Subs- 2 Obsidian Audio 12 d4's
Box 4ft^3 ported at 33hz. designed by Ram-Designs
id leave it the way it is, its just one big circle basically
from what understand ur also grounding the alt to the car itself/chassis when grounding the engine. some alts like mine, dont have a actual bolt on the alt to ground it off so grounding the engine is the next best thing
on mine i went a bit over board:
2x-0g and 4g from neg on battery to chassis
2x-0g from engine to chassis(different spots)
1x-0g from alt to battery
4x-0g to rear batteries from alt
2x-0g from neg on battery to rear batteries :)
That is a poop-ton of 0ga my friend haha
so far...
Posted (edited)
yeah all welding wire, 100ft of it :) not too bad on price actually like $300 or so
its actually nothing compared to what some of the bigger builds on here have
Edited by BeatBox
Yeah like last Friday I ordered 25' of monster (got a good deal on it cause the company was making room for new stuff) for $75. But today I went in my shop to do some stuff on my dirtbike and I spotted like a 50' strand of welding wire laying in the corner under a bunch of crap and I was like DAMN haha
so far...
Oh and sorry I didn't answer the question earlier! I am going to do my big 3 first with the monster and I am going to run all the wires to my amp in monster 1/0 also... But then after I was going to piggy back the 4ga original wire that goes from batt to batt with a piece of that cadence 0ga, I would have bought more of that cadence but I don't really like it, a whole spool of it weighs like as much as 1ft of monster lol
so far...
its good wire, for the price cant beat it i got mine from here
its pretty heavy compared to regular wire of the same size/length
http://www.powerwerx.com/wire-cable/welding-cable.html
Does it carry up to 300amps? The 1/0 gauge? is it close to the Knu good stuff?
Posted (edited)
its been working fine, i havent clamped it for exact numbers. i have 300A ANL fuses on mine
its prob alittle smaller than the knu wire, but for being pure copper ill take it
techforce also runs it in his truck i believe
Edited by BeatBox
I'm sure that it is! It's most likely just a little bit less flexible because car audio companies want their cable to be flexible more than anything it seams like. But I imagine if it's welding wire that it is good copper
so far...
