AA98hoe Posted July 1, 2011 Report Share Posted July 1, 2011 Eric i talked to you this morning about the pulley being loose, so i went to a buddys shop and he impacted it real quick like a second. anyhow i put it on and it lasted for 5 mins. i took the belt off after this vid and the pulley was loose again. do you think the noise is the pulley,or windings? or? Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
crunkjuice1 Posted July 1, 2011 Report Share Posted July 1, 2011 I would call first thing friday morning and tell them to check the link out in here. there weekend ends tuesday I think. Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted July 1, 2011 Report Share Posted July 1, 2011 Ray- Send it back to us for repair and we will get it resolved. This should be removed from your system so it is not damaged. So that everyone knows, this unit was purchased second-hand from the original purchaser. We do not know the condition or handling of this unit between the original purchaser and the current installation and will need to inspect the unit to determine the problem. I'm not saying Ray did something wrong, just that the handling and use of the unit by the previous owner is unknown at this point. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
AA98hoe Posted July 1, 2011 Author Report Share Posted July 1, 2011 Thank you Eric and Matt for excellant customer service and a awesome product. In no way am i trying to bash mechman. i love there product and my 400a comp is my daily alt. ive had zero issues with it. I think we solved the issue, i will know shortly. It should just be a loose pulley.if not ill send it in. Thanks again Eric and mechman FTMW! Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
MECHMAN Posted July 1, 2011 Report Share Posted July 1, 2011 Good to hear it is resolved. Tighten that thing up good! Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
MECHMAN Posted July 7, 2011 Report Share Posted July 7, 2011 Ray, now that this one is handled by tightening the pulley we can get that Iraggi unit back to you. It's now built to Mechman specs and will put out the power you want! Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
AA98hoe Posted July 7, 2011 Author Report Share Posted July 7, 2011 Thank you matt and eric and all the mechman crew for fast ,excellant service. And a awesome product. your alternators are helping me put up big numbers at my shows,hopefully they get bigger. mechman ftw! Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5. Link to comment Share on other sites More sharing options...
