First time designing a box, and I was wondering whether you veterans can spot any problems with this enclosure. Bear with me, the model is not 100% accurate (first time using the program)...
This will go into the trunk of my Camry (unsure of year), so that's why the dimensions are so small.
What type and size sub, for 6 cubic ft It looks like an 18 but u need alot more port
You're right, a Fi BTL 18 N2. As for the port, making it larger in diameter also makes the length requirement higher too.
Edited by Shigshwa
brace from left to right. up and down and at least 2 braces from the baffel to the back and bottom.
you can also port through the rear deck so you have more room with the port. or through the armrest if you got one in your rear
Edited by optical
you need a shit ton more port...and how do you not know what year your car is?
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
Port area per foot needs to be at least 8..keep trying
Build in Progress
Hmmm, and simply adding more ports does not work, right?
IT works but then you also have to take into account the space the ports take up in side the box.
¿ǝɯɐƃ ǝɥʇ
  • Who's Online   0 Members, 0 Anonymous, 624 Guests (See full list)
