Hostility Posted July 7, 2011 Report Posted July 7, 2011 well ive built many boxes for my ext cab s10 over the past 2 years, and ive never really been happy with it. Right now im running 3 sa12's on a saz 3500. my box currently is 5.26cubes @ 31hz with 81.25 in2 of port, with subs firing forward, port up drivers side. The box i tried before this was subs forward, 2 6" aeros firing up @ 36hz. I liked the box with the aeros but wouldn't play the lows i wanted it to (but found out later after 2nd box my ssf needed to be turned down, so im not truly sure if it would play the lows i wanted it to or not. So my question is, is there anyone with experience with trucks like these, and what should i do next? i would like to reuse my 6" aeros if i could. 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
Hostility Posted July 9, 2011 Author Report Posted July 9, 2011 bump 99 s10 4.3L Big 3 220amp alt Odyssey 1500 Odyssey 2150 Northstar NSB 75 Sundown Audio 3500D Sundown Audio 125.2 3 Sundown Audio SA-12's Alpine H/U RF Power Comp set 6.5" RF 3 sixty line driver 5.25 cubes @ 31hz
fox_racin4 Posted July 9, 2011 Report Posted July 9, 2011 hahah sup Gary? i know my trucks not an S10, but ive had best luck with subs forward port up ( my ports have been in the middle tho) and my truck also lovesss lows ( peaks at 28hz while tuned to 37!) 1998 gmc extd cab 12 crossfire C710s 4 SAZ-4500s 3 Singer 400A altsbuncha mids/highs Team Asshole
Team Bassick - Kimo Posted July 9, 2011 Report Posted July 9, 2011 Musically the best set up I feel is subs forward ports up. I must of done over 50 boxes for my s10 and that was the best configuration. 2 15's and 4 4" flared ports worked best. I am going to try it with 3 6" full length (18") next. Currently I have a wall of 4 15's with 4 6" flared corner loaded. Sounds good but, Numbers SUCK!!! So going scrap the wall and go back to a daily set up. KIMO @teambassick http://www.teambassick.com
OldsBoomer Posted July 9, 2011 Report Posted July 9, 2011 Yea do subs forward with ports in the middle tune to 32 and give them about 6-6.5 cubes Suburban Coming Soon
