So i am getting a DC lvl 3 sub with Lvl 4 coil and soft parts looking for a amp 1 ohm stable that will put out 1000rms at 1 ohm? and what fuse holder and fuse would i need? And would i want to upgrade batteries right away? and would i also want one in the rear...?
2008 Dodge Avenger SE
Pioneer 4300-UB Headunit
DC 1.2K
10"DC Lvl 3 with Lvl 4 coil...
15" DC Lvl 4
JVC Arsenal 3-way Component set
Cause the amp i have now will only put out 300rms to that sub... which im thinking wont be that loud but will see
DC 1.2K
15" DC Lvl 4
Audioque 1200d does 1200 rms at 1 ohm. I'd run a 100-120 amp anl fuse with true 4 gauge wire. As far as a battery I would do the big 3 with 0 gauge wire and see how your voltage holds up
Edited by baaudio
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
Ok thank you im using this for research... so when i have the money i can get more power... How bad is it to run one coil instead of both cuz my amp now is only 2 ohm stable the sub im gettin is dual 2 ohm so either i have to wire it to 4 ohms or get a new amp or wire it to only one coil for max power output from amp which aint even half of half the 1000rms the sub will handle
DC 1.2K
15" DC Lvl 4
Don't wire only one coil. I'd run it at 4 ohms for a while just to break it in. Then once you upgrade amps you'll be good for full power
Team NWSPL
baaudio Build Log
Ya thats what im going to do... lol? What all will i need to run that AQ1200? How much will i need to save b4 i can upgrade amps? Running stock everything right now.... What do you guys think i could hit with that DC 10 on only 300rms? Did 130 on 450rms on a 10 alpine type r so idk?....?....?
DC 1.2K
15" DC Lvl 4
  • Who's Online   0 Members, 0 Anonymous, 847 Guests (See full list)
