1994 Camaro V8 Problems
pull your plugs and check for oil. make sure they are the right temp. Check your wires also. Im at work so i could not watch the vids. Start the car and look under the hood for any vacuum leaks. Do you smell gas after you start it?
Mark
99 Eclipse Spyder
sounds like the timing might be off....if you got a timing light shoot it.
x2 on the vacuum leaks too.
also check your wires to the plugs and your dist. cap. sometimes the points in the cap wear out.just my 2cents
ya you can smell gas.
wires, plugs, dist, and cap and rotor were all replaced about 4 months ago
