Brand New....need to sell only because I ended up purchasing a subwoofer that requires a different amp. See it at Best Buy for $700 plus hst plus extended warranty plan. This amp includes a transferable Best Buy service plan extended warranty that is good for another 3 1/2 years.
1500 Watt Mono Subwoofer Amplifier with built-in variable electronic Crossover and Dynamic Bass Optimization Circuit (DBO).
The GTO14001 has been engineered to ensure optimum power delivery into numerous impedances with low distortion. It comes outfitted with a variable 12dB per octave electronic crossover allowing you to optimize subwoofer tuning based on location and accompanying loudspeaker components. It also includes JBL's Dynamic Bass Optimization Circuit which provides variable filtering with adjustable Q below 100Hz. This circuit allows tuning of any enclosure to any vehicle. Full range preamp outputs are provided facilitating multiple amplifier hookups without the need for high-loss Y-adapters or signal splitters.
Specifications close
Description1500-Watt Mono Subwoofer Amplifier
Output power (RMS, ≤1% THD + N; 2 ohms)1500W RMS x 1 channel
Output power (RMS, ≤1% THD + N; 4 ohms)1200W RMS x 1 channel
THD+N0.05% (rated power @ 4 ohms)
Maximum power1500W
CrossoverBuilt-in variable electronic crossover
Frequency Response20Hz -- 330Hz (--3dB)
Signal-to-noise (@ 1W)77dBA (reference 1W into 4 ohms), 108dBA (reference rated power into 4 ohms)
InputsRCA low-level preamp inputs
OutputsRCA low-level preamp outputs
Back-litJBL logo badge & dual LED light bars
Dimensions (L x W x H)18-9/16" x 10-3/8" x 2-1/8"
there are rules for selling, please read..
your username is no fucking joke...wrong section, not enough posts, and you didn't even get the format right, gtfo. <_<
c'mon now, if i was shooting an 8 year old, it wouldnt be MY 8 year old.
i recently got a Pyle PL1590BL and i was building an enclosure for it tuned to 25 hz. i didn't have any tools to cut a circle so i hit it with a big hammer.
2003 Infiniti G35 Sport Sedan
Build in Progress
This topic is now closed to further replies.
