this is a project i started today. this is a 1994 s-10 blazer that will get all of its interior removed and sound deading applied. well for sound deading patrick from robotunderground suggested 1 part silicone 2 part caulk mixed 2gether with 60 grit sand for wieght. thats 2marrow and we will see how it works out. after sound deading the blazer i will build a enclosure for 4 15" brahmas. the enclosure will have a black high gloss finish, kerfed port and fiberglass on the inside, double baffle, and alot of internal bracing.
after subs and box are installed, the memphis mcd4k amplifier will be mounted just behind the front seats, along with 2 deep cycle batteries. then run all the power cables and speaker wire. install 3 componet sets. also the center console is hammer so i will do something to fix that up. also a 200 amp alt needs to be installed. there might be somethings i forgot.
well these are the pictures for today
DAY 1
before
after
2marrow sound deading..........
