Here is my technique and it works for years now, been doing this on dozens of installs, for subs, I never use tnuts but instead use #10 pan head steel screws you can get a box of like 100 for cheap, I use 1.5 inch long and use that in conjunction with a 1.5 inch or thicker baffle, on some I have reused the same holes over a dozen times with 60 lb woofers. For removable and tunable ports I use tnuts usually 5/16 cuz they are less likely to spin on you and strip out and I use in conjunction with those gorilla glue on the points of the tnut that way those sucker don't move.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
That's pretty much what I use #10 panheads length depending on the MDF thickness. But the question is what about when you remove the subs? You can't just drill a #10 back in there because since it's practically sawdust if your lucky you'll get a tight hold. Which is why a metal ( or hurricane nut ) would come in handy. From what I cam gather the hurricane nuts are easier to use and you get just about the same strength. Mind you that I am not doing a wall holdin an 80+ lb sub. I'm Doing 25lb subs upfiring. But I was really just asking questions to learn a little more..incase someone were to ask me I could pass on the knowledge.
But thanks everyone for the input. I did learn a bit! He'll didn't know these existed before I posted :lol::noob:
1/0 Power Wire All Around + Big 3 - $140
Rockford Fosgate T2500-1BD - MSRP $1800
(4) Memphis M3 10" Subwoofers 1600watts $300ea. = $1200
XS D6500 $245.65
PIONEER AVH-P5200DVD 7" Head Unit = $430
Soundstream SC-6T Component 6.5" FRONT $60
Pioneer TS-A1673R 6.5" REAR $85
A Bangin system! = PRICELESS!
I have never had a problem with the pan screw going back in and holding fine. I have taken some of my hdc3s in and out over a dozen times easy. Still hold just as strong.
Evo X build log
I've never had a problem just drilling into MDF with coarse thread screws...
I must be doing something wrong It usually gives a good strong hold the first couple of times and gradually gets weaker.
I also use pan head screws to hold the subs in place. But after I remove the subs a few times the holes seem to get much weaker.
XS D6500 $245.65
  • Who's Online   0 Members, 0 Anonymous, 820 Guests (See full list)
