if the switch i am using has an LED, could i wire it inline with the remote turn on lead instead of off the battery? (i dont want to run them off the battery because if i forget to flip the switch of, the amp will stay on even if the car is off.) or is there a way to wire inline with the remote and still get LED power?
switch is the LED rocker switch
http://www.youtube.com/user/blown72olds#p/a/u/2/EXvLTOd5K0c
Yup, you can run it off the remote turn on.
Only difference between a switch with an LED and one without is the fact that you have to complete the circuit of the led, which means a ground needs to be added to the switch. LEDs are very efficient, so it shouldn't lead to any problems regarding the amperage draw in your remote wire.
  • Who's Online   0 Members, 0 Anonymous, 822 Guests (See full list)
