ChevyBoy95 Posted July 14, 2011 Report Share Posted July 14, 2011 if the switch i am using has an LED, could i wire it inline with the remote turn on lead instead of off the battery? (i dont want to run them off the battery because if i forget to flip the switch of, the amp will stay on even if the car is off.) or is there a way to wire inline with the remote and still get LED power? switch is the LED rocker switch Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
Blackedout Posted July 14, 2011 Report Share Posted July 14, 2011 if the switch i am using has an LED, could i wire it inline with the remote turn on lead instead of off the battery? (i dont want to run them off the battery because if i forget to flip the switch of, the amp will stay on even if the car is off.) or is there a way to wire inline with the remote and still get LED power? switch is the LED rocker switch http://www.youtube.com/user/blown72olds#p/a/u/2/EXvLTOd5K0c Yup, you can run it off the remote turn on. Only difference between a switch with an LED and one without is the fact that you have to complete the circuit of the led, which means a ground needs to be added to the switch. LEDs are very efficient, so it shouldn't lead to any problems regarding the amperage draw in your remote wire. Trunk Build Log Link to comment Share on other sites More sharing options...
ChevyBoy95 Posted July 14, 2011 Author Report Share Posted July 14, 2011 YEEEEEEEEEEEEEEEEEEEEES! thanks Best Score to Date : 160.5 dB Outlaw (47Hz)[4 XM 15's & 2 Taramps Bass 12k's] BL : http://www.stevemeadedesigns.com/board/topic/147800-chevyboy95s-4-15s-7krms-wall-1533-db-on-half-power/YouTube: http://www.youtube.com/hitemwiththeflex/ Link to comment Share on other sites More sharing options...
crunkjuice1 Posted July 14, 2011 Report Share Posted July 14, 2011 Awesome link Blackedout thank you for sharing Link to comment Share on other sites More sharing options...
Blackedout Posted July 14, 2011 Report Share Posted July 14, 2011 Yup. Tony, who is on the forums, made that video.... He wrote a book that's pretty good for what we're doing too. http://www.google.com/products/catalog?q=automotive+wiring&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&hl=en&ie=UTF-8&tbm=shop&cid=14189848290407482878&sa=X&ei=_78eTu-6GaXRiAKw3vWiAw&ved=0CGsQ8wIwAA Trunk Build Log Link to comment Share on other sites More sharing options...
