heres my problem ive been working on my caprice to get it ready to paint and i got it in primer and went thru 4 mini desicant and 3 paper filter that screw on the gun. spraying a quart of epoxy primer and a gallon of primer on the car. my compressor is a 80 gallon ingersoll rand single stage pump rated 18.1 cfm at 90 psi well my water prob coming thru the lines is so horrible lol i dont wanna spray the paint and waste a bunch of cash on paint i have 2 filter/water separators on 1 line already roughly 30 ft away from the compressor that im using and it helps but not very well im getting roughly 0.5 to 1 tablespoons of water coming thru the lines every few mins. does anyone have any suggestions on a way to get rid or help get rid of the water coming thru the lines.
89 Chevy Caprice (is under construction)
dual alts
4/0 welding cable for wire
red top under hood 3 yellow tops behind the front seat ( who needs a back seat anyways lol)
big 3 of course
Eclipse 3000
interiors are getting rebuilt now
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
Many times its simply atmospheric conditions that play a role in that, but it could also be insufficient separators or low quality hose
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
maybe its my compressor i think its pissed lol i ran it for 3 days sanding and grinding at the same time me and my cuz were working on it and not 1 drop of water and then all of a sudden boom a flood lol
dual alts
big 3 of course
Eclipse 3000
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
Do you open the dump valve on the bottom after every use?
a few times while using it and then a complete drain after im done on the tank and filters
dual alts
big 3 of course
Eclipse 3000
2 crescendo bc2000
2 shocker sig 12s
rebuild pics
