Right i have a sub box for 3 10s and it hasnt been fiberglassed inside yet and i want to fiberglass it my self and i was wondering what i need to buy and what kind of procedure it needs so it can be fiberglassed.
2001 peugeot 106 quicksilver
4 beyma 8''
2 titanium bullet tweeters
1 soundstream ST-T15 custom box made
1 hifonics brutus 2400.1
1 cadence c9 competition 100.4
1 SVR 2000P batterie
0 gauge cadence power wire
145.3 @ 42Hz
are you just wanting to reinforce the inside of the box for stiffness? if thats the case many people just resin the walls and some may even lay fiberglass in the corners
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
if you are actually wanting to build a fiberglass box, then go to the fabrication section, theres a couple stickys you can check out about fiberglassing
1969 Chevy Chevelle
MY BUILD
fiberglass resin by itself will not add strength, id get some 3M fiberglass resin(make sure it has hardner too), some paint brushes, and fiberglass matt.
put the resin down first so the matt sticks then soak the matt in resin and let dry. dont put too much hardner or the resin will dry way to quick and you may end up wasting alot
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
yep just reinforce it but if you could link some stores that have the kind of stuff i need cause i dont know what exactly need. thanx alot
4 beyma 8''
145.3 @ 42Hz
home depot or lowes will have everything you need
1969 Chevy Chevelle
MY BUILD
1969 Chevy Chevelle
MY BUILD
i have to disagree with that. mdf has micro pours that the resin penetrates and allows it to harden, thus creating a stiffer piece
1969 Chevy Chevelle
MY BUILD
i live in greece so its ckinda hard to get stuff from america so if you could point out some brands and some types of resins and what kind of fiberglass i will need that would be very helpfull :)
4 beyma 8''
145.3 @ 42Hz
compare the strength of just resin to resin and matt, night and day diffrence, but i use birch
  • Who's Online   0 Members, 0 Anonymous, 619 Guests (See full list)
