They are not running at 2 ohms then, if using only 1 amp...
But say he's only running 2 of the 4 coils, getting a 2 ohm load. That's the only way i could think of. But then again.. i'm not too sure.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
If that's the case, then those subs won't last very long. Lol.
Simple answer-Just run all 4 positives together and all 4 negatives together. You will have a 1 ohm load, and will get the most out of your amp/subs.
The link posted above sounds a little different from what you are saying would this be the right way then or no there is a different way.
Posted (edited)
Yeah, You should be fine. Just wire it that way and you will have a final load of 1 ohm going into the amp.
And the reason why you said it looked different, Is because it shows you, you can wire it to 1 ohm or 4 ohm. But you want to wire it to 1 ohm, and that's what you posted so you will be fine.
Edited by Katt
Alright Thanks Guys and Thanks Katt.
No problem, It's always better to ask and make sure then something go horrible wrong. ;)
