I have a quick question hopefully someone can help me out. I have 2 15s at 750RMS running at 2 ohms right now, would it be a bad idea to run my subs at 1ohm even though they say to run them either at 4 or 2ohms. Btw the brand is Diamond Audio and both Dual Voice coil. Sorry for the noob question.
Thanks
What impediance are your subs?
2001 chevy cavalier
Rebuild in progress
what happens when your CD player skips and you accidentally drop a 22 hz sine bomb at an unholy volume on 7-8 year old subs? Mechanical failure floppy sub knockage on at least 2.
well...as i see the level 6 is compared to a lamborghini.....but a corvette?
i was thinking more like a chevy volt. its cute and new and "hip", but i would just rather stick my dick in a blender.........
I don't think it would hurt em
Edited by vettedude102
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
If you have two D4s, you're not running them at 2 ohms now. It's either 4 or 1. Unless you're running two amps.
All parallel=1 ohm, series/parallel=4 ohms.
Look at the12volt.com like already suggested
Edit-well, I thought it was already suggested lol. Maybe that was a different thread. Anyways, the12volt.com has wiring diagrams.
Edited by bassfiend316
What amp are you running to the subs?
Just ordered a Soundstream TX1.1300D so they will be powered by that.
Yeah you can run it at 1 Ohm. Just to be sure, Watch your voltage to make sure it doesnt drop low, and set your gain's right so you don't clip and blow your subs.
Here's how you would wire it. http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42#results
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
  • Who's Online   0 Members, 0 Anonymous, 530 Guests (See full list)
