4ohm to 1ohm wiring help
They are not running at 2 ohms then, if using only 1 amp...
But say he's only running 2 of the 4 coils, getting a 2 ohm load. That's the only way i could think of. But then again.. i'm not too sure.
*06 330i - Sundern x12 - saz-3500*
*91 Foxbody V1 S-Trim Notch*
If that's the case, then those subs won't last very long. Lol.
Simple answer-Just run all 4 positives together and all 4 negatives together. You will have a 1 ohm load, and will get the most out of your amp/subs.
The link posted above sounds a little different from what you are saying would this be the right way then or no there is a different way.
Yeah, You should be fine. Just wire it that way and you will have a final load of 1 ohm going into the amp.
And the reason why you said it looked different, Is because it shows you, you can wire it to 1 ohm or 4 ohm. But you want to wire it to 1 ohm, and that's what you posted so you will be fine.
Edited by Katt
  • Who's Online   0 Members, 0 Anonymous, 1230 Guests (See full list)
