Cliping help
Also in the midst of getting a new car..... kinda hetic i know...
2001 is300Headunit: JVC KD-X50BTHighs/Mids: StockHigh/Mids Amp: NASubwoofer: DC Audio LV4 12"Subwoofer Box: DLDesigns Box tuned to 32HzSubwoofer Amp: AQ 2200DElectrical: NA Performance:SRT Racing intake with ECUHKS Super Dragger 2BC Racing Coilovers
BC 264 stage 2 cams
full head build with BC Valves, Retainers, and springs
Dezod Green Race Header Comming soon/Thinking about<p>Electrical: XS power under the hood (Suggestions Welcome)​Performance: BC Cams,Cam gears, maybe GTE Swap down the lineMy YouTube Channel Subscribe and i'll return the favor!Xbox Live Team Website.My First Official Box Build.My FacebooK
What he was saying was if your amp is clipping... it doesnt matter what you head unit volume is at... So to be on the safe side.. just set your amp about half gains.. and find out the number your head unit clips at.. someone said 34 or 35 or something so dont go past that.
Also x2 on the DD-1... or find someone in town who has one that has 5 spare minutes...
Yes i have my gains at halfway but i was wondering if i turned up the SW Lv on the Hu will it make it clip at a sooner point? same with treble bass and mid Lv? :shrug: i am trying to get a DD-1 Beleave me lol but im still trying to get a DMM and lots of other things new Batt stuff like that....
Bumpppp on this question ^^ :pardon:
BC 264 stage 2 cams
And can i tune my amps with a DMM?
BC 264 stage 2 cams
Bummmppppppppp :clapping:
BC 264 stage 2 cams
Yes. You have the headunit outputting more at the RCAs. Eventually they will clip. If they don't, when you pass on the signal to the amplifier, unless the gain was low to begin with, it will clip.
Basically the SW level etc. are gain knobs themselves.
The only exception to this rule I'm aware of is Alpine units. Their SW level is wonky in that at 15 you are at 0db. So set your gain with the headunit at the max you will ever go. Make sure that doesn't clip. Then go to the amplifier with the deck at that maximum output level and set the gain there.
A little searching goes a long way.
And as for the DMM...are you sure you're really getting rated power? If not since you have no way of seeing the waveform, its entirely possible you will still get 1000 watts to exit the amplifier. However, its also possible its dirty power.
Edited by BJD3
DC Level 4 M2 12 D2
Car Audio Bargain 1600.1
Eclipse CD3200
~2 cubes @ 34 hz.
Stinger Roadkill Expert
Thats why i want to get a DMM so i can check my voltage. also its a D4 sub so im only getting like 750W if im at good voltage i did the big 3 but the headlights still dim..
BC 264 stage 2 cams
Doesn't matter. If you don't know the signal amplifier is actually outputting, the DMM will tell you the amplifier is outputting more power. And it is. But the signal is could be distorted/clipped.
DD1 >= Oscope > DMM > ear > crank and bang.
Edited by BJD3
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
How would I check it with a dmm?
BC 264 stage 2 cams
http://www.stevemeadedesigns.com/board/topic/14666-calculating-gain-voltage/page__hl__setting+gain
http://www.stevemeadedesigns.com/board/topic/4382-setting-amplifier-gain-control/
Now read this:
http://www.stevemeadedesigns.com/board/topic/4382-setting-amplifier-gain-control/page__view__findpost__p__498392
And considering with a DD1 you can find 1% distortion and not just clipping, it is (IMO anyway) the better tool.
Edited by BJD3
DC Level 4 M2 12 D2
Eclipse CD3200
~2 cubes @ 34 hz.
The better tool indeed I just need to save some skrilla so I can get one
BC 264 stage 2 cams
  • Who's Online   1 Member, 0 Anonymous, 1373 Guests (See full list)
