Excurzion Posted July 24, 2011 Report Posted July 24, 2011 I am planning on running a second aq2200 or a single aq3500. Wich would be more power hungry two aq2200s or a single aq3500.1?
armykyle1 Posted July 24, 2011 Report Posted July 24, 2011 If each combo is run 1ohm the the two 2200 TEAM XS POWERTEAM HEAVY HERTZMy build- http://www.stevemeadedesigns.com/board/topic/194454-e46-bmw-build-pos/#entry2914134youtube- http://www.youtube.com/user/armykyle1big build starting
brennan88 Posted July 24, 2011 Report Posted July 24, 2011 I would say the 2 2200 would have more draw, as they need 200 amp fuses, 400 total as opposed to one 380, it'd be off by only 20 amps. I'd probably tun the 3500. Just seems easier and less of a hassle. But they're close enough, that it wouldn't matter. But another 2200 might be your best bet, cheaper. Imo. '04 Walled Monte Carlo daily driver2 DD 9518i SC D.7 DD M4a 2 sets RF T165-2s (soon to be 3) RF T400.4 Mechman 320 XS D3100, D3400 https://www.youtube.com/user/OffensiveProduction1
Excurzion Posted July 24, 2011 Author Report Posted July 24, 2011 Well my subs are both dual 1 ohm so if I strapped the aq2200s I heard they arnt very efficient below 2 ohms..??? And I can only run my subs togather at 1 or 4 ohms so I'm kinda confused on how the whole strapping thing works lol
brennan88 Posted July 24, 2011 Report Posted July 24, 2011 lol, it's not hard. Instructions come with your amp on how to wire for strapping them. You could just run each amp @1ohm, but then you'd need to make sure to have both amps tuned and adjusted the same. But in that case I'd just go 3500 then. And either sell the 2200 or garage it as a spare or something. '04 Walled Monte Carlo daily driver2 DD 9518i SC D.7 DD M4a 2 sets RF T165-2s (soon to be 3) RF T400.4 Mechman 320 XS D3100, D3400 https://www.youtube.com/user/OffensiveProduction1
Katt Posted July 24, 2011 Report Posted July 24, 2011 lol, it's not hard. Instructions come with your amp on how to wire for strapping them. You could just run each amp @1ohm, but then you'd need to make sure to have both amps tuned and adjusted the same. But in that case I'd just go 3500 then. And either sell the 2200 or garage it as a spare or something. If you strapped them, You only need to set one, The one you set is the Master, and the other is the slave, And you don't need to set. Strapping isn't really that hard. Just make sure you can back up the electrical so you don't drop too low and blow your amps. *06 330i - Sundern x12 - saz-3500* *91 Foxbody V1 S-Trim Notch*
