What ohm load to u want to run the T1000's at? If you want 1 ohm on each t1000's get dual 2 ohm subs...that is if you want to run an amp to each sub.
Edited by zaxfire69
yea in order to get 1000wrms it needs to be one ohm so I need to get the dual 2 ohm bl's? ....if anyone can show me how to wire them that would be great...thanks all...sorry im a newb
A vitrolic, megalomaniacal sadistic psychopath.
Wire each coil together...+ + On one speaker.. Each coil is 2ohms wired together meaning coil 1 + and coil 2 + Coil 1 - and Coil 2 - Just wire them together and connect them to the amps + and - That will give you one ohm at the amp...
Use this for reference..All you need to know..Enter your coil configurations
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Did it for you..Scoll down to bottom of page..2 choices with dual 2 ohm coils.
http://www.rockfordfosgate.com/rftech/woof...mp;woofer_imp=3
Edited by zaxfire69
Thanks man that was really helpful :)
