I just purchased 4 new (1999) Orion xtr pro 12s, and am wanting to start planning a box for them. I was thinking around 6 cu.ft airspace with a square blowthrough port tuned at around 30 hz? Does this sound reasonable, or should I go a little bigger? They will be powered by an audiopipe ap30001d set at 2000rms @2ohm. As well this setup is going into a gmc safari van. Thanks.
Do you have any specs?
Yes sir.
SENSITIVITY @2.83V/1m----94dBS 88dBP
Fs FREE AIR RESONANCE----24 Hz
Qms MECHANICAL Q---------9.345
Qes ELECTRICAL Q --------0.339
Qts TOTAL Q--------------0.327
BL FORCE FACTOR----------9.85P 19.7S
SD PISTON AREA-----------522 CM2/81in2
VAS----------------------134 LITRES/4.73cu.ft
X-MAX--------------------10.5 mm/.41in1
RMS POWER----------------500w
MAX POWER----------------1000w
BASKET DISPLACEMENT------244CU.IN/4.0Liters
VOICE COIL---------------2.5 Inch
Edited by detroitdiesel
Ok, I entered the 4 12inch Subs into winISD, and it recommends 9.7 cu.ft, and 29hz tuning. With the motor being limited in xmax, wouldn't i be better off sticking the subs into a box more along the the lines of 7-8 cuft.? If i go too big, wouldn't i run the risk of bottoming out the subs at low end frequencies at rated power??
Also, i am going to try and make this box in sketch up, so i will post it up before i start building.
