I need to build a box for 2 type-r 15's dual 2 ohm. I have all the stuff but can not design it. I want it tuned to 35hz and loud for daily driver. I can not find any good plans online for a box for 2 of these woofers. I tried the 12 volt calculator but I'm lost on the port size. If anyone can help it would be greatly appreciated thanks. I am open to any of your thoughts or ideas/recommendation etc. preferably 36-38 inches wide would be good
check out Torres Box Calculator on here. Go under subwoofer/enclosure and it will be at the top
Yeah I will try that but the main problem is i'm not sure which design woud be best. Like a center slot port, side slot port or a seperate port for each woofer?
I wouldn't do a seperate port for each. I'm not sure if it makes a difference between center slot and side slot but I always do the center slot port.
ok so one port in the center for both subs? do you make an L port or just straight back.? I cant figure out the torres calculator... i am horrible at math
Yeah you make them L ports. Make sure for # of common port walls put 3.
how do you account for the L's in the port? i have it worked out to 34hz with a 13.3 long port but i dont know how to figure out the L's. I selected 3 common walls like you said
  • Who's Online   0 Members, 0 Anonymous, 822 Guests (See full list)
