TeejayBee Posted August 2, 2011 Author Report Share Posted August 2, 2011 okay max dimensions are Depth 16.5 if i take the amp off the floor id prefer to keep it there but if i do its 15" deep Length is 38" and height max is 24" so now lets start the designs and ideas Quote Link to comment Share on other sites More sharing options...
Tarball Posted August 2, 2011 Report Share Posted August 2, 2011 okay max dimensions are Depth 16.5 if i take the amp off the floor id prefer to keep it there but if i do its 15" deep Length is 38" and height max is 24" so now lets start the designs and ideas is this a 12" 15" or 18" sub ? Quote CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db Link to comment Share on other sites More sharing options...
TeejayBee Posted August 2, 2011 Author Report Share Posted August 2, 2011 sorry 15" imo im thinking sub up port up will be best, only for the fact that if i do the sub back it will hit the hatch on flex and idk port just seems to be able to fit better up , Quote Link to comment Share on other sites More sharing options...
TeejayBee Posted August 2, 2011 Author Report Share Posted August 2, 2011 Okay olds boomer got a some dimensions for me, Box idea one Height Width Depth 17.25 37.5 16.5 Port Height 15" Width 3.75 Length 22" tuned to 32hz Quote Link to comment Share on other sites More sharing options...
RAM_Designs Posted August 2, 2011 Report Share Posted August 2, 2011 (edited) Okay olds boomer got a some dimensions for me, Box idea one Height Width Depth 17.25 37.5 16.5 Port Height 15" Width 3.75 Length 22" tuned to 32hz 37.5" x 17.25" x 16.5" = 4.92ft^3 before sub and port displacement 15"x4.5"x22" = .86ft^3 for port displacement Left's say .15ft^3 for sub displacement So without any bracing you're looking at 3.9ft^3 after displacements. A 3.9ft^3 box with a 15"x3.75" port that's 22" long gives you a 37hz tuning. A 32hz tuning using the same net volume would require 31.75" of port length. It looks like he was finding the port length based on the gross volume of 4.92ft^3, which is not the right way to do it. Edited August 2, 2011 by RAM_Designs Quote Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011... Link to comment Share on other sites More sharing options...
TeejayBee Posted August 2, 2011 Author Report Share Posted August 2, 2011 why you gotta be so damn smart =p lol i littraly am lost at box making so ill most likely hit you up but id love to have sub up port up, and when you look at the box port is on the left and sub is on the right, Quote Link to comment Share on other sites More sharing options...
