No they are not designed to run 2 ohm bridged.
Isobaric - Refers to the practice of coupling two drivers together to make them act as one.
"Giving up doesn't always mean you are weak; sometimes it means that you are strong enough to let go."
Insanity: doing the same thing over and over again and expecting different results.
The Destruction of a person builds character.
Will the sax 125.2 run at 2ohm bridged?
Yes they will,but they do not like it.I had one running 2ohm mono but in the Cali heat it got hot and would shut down---not good.Yes they will play but not for too long in 100 plus heat.
Eddie
What if you ran it at 2 ohms bridged on high pass???
2 DC Audio lvl 4 xl 18s D .7s walled off @ 30 hz
19 cubes net 245sq in of port
Sundown 3500 @ .7 Ohm
Sundown 100.4
Rockford Fosgat Power Series
5.25 Dash
6.5 Kicks
8 Coaxils Doors
250 mechicman alt
1 red top under the hood
2 yellow tops in back
big 3 with 1/0 knukonceptz wire
3 runs of +/- 1/0 knukonceptz wire
IT LBS
  • Who's Online   0 Members, 0 Anonymous, 1196 Guests (See full list)
