iCool247 Posted August 4, 2011 Report Posted August 4, 2011 As of right now, my money is tight and I'm going cheap. I was wondering how do I hook up an amp to my stock head unit. I believe I can not use RCA's because of the stock head unit. I was thinking about going with the MTX Terminator package(2 12's & 1 1200watt amp). The amp it self is a class D mono block. And how do I hook up 2 subs to a mono block amp? '01 2DR GMC JimmyPioneer DEH-6300UBMB Quart 6.5'sSoundown Audio SA 8 V2'sMTX RT-202 GONEAudiopipe AP-1800.1D GONE Bass-less
LivinloudDD Posted August 4, 2011 Report Posted August 4, 2011 You will need one of these to hook a amp to the stock radio. dodad splice it to the harness. Running the subs wire both postitive and both negitives together then run a positive and negitive from one sub to the amp. Speaker wiring Hope this helps you 99' Chevy S10 4 Yellow top optima batteries Stock alt gonna be changin soon 1 run of Stinger 0 gauge Alpine 105 Clarion EQ 2 Digital Designs M2a Hifonics 100.4 Pair of older model DD 6.5 new T2 tweeters. 2 Tantric Sound HD 15's 15s 155.5db outlaw
jake1993 Posted August 4, 2011 Report Posted August 4, 2011 does the amp have "high level inputs"? if you give us a link to the amp might be helpful. whats it going in? Jacob Sigmund 1 dc level 4 m1 18 1 audiopipe ap1500 2 runs of knu 1/0 Alex Bennington" <[email protected] ^^^ want one one email this guy he will hook you up!
iCool247 Posted August 5, 2011 Author Report Posted August 5, 2011 does the amp have "high level inputs"? if you give us a link to the amp might be helpful. whats it going in? Ok this this the link to the amp --> MTX Amp Its going into a '01 2dr chevy blazer '01 2DR GMC JimmyPioneer DEH-6300UBMB Quart 6.5'sSoundown Audio SA 8 V2'sMTX RT-202 GONEAudiopipe AP-1800.1D GONE Bass-less
Guest Posted August 5, 2011 Report Posted August 5, 2011 does the amp have "high level inputs"? if you give us a link to the amp might be helpful. whats it going in? Ok this this the link to the amp --> MTX Amp Its going into a '01 2dr chevy blazer yeah that amp has high level inputs already built into it. sweet, makes it that much easier. you look on the amp itself and right below it it tell you which wire goes to which speaker and whichever polarity (+ or -). then the G in the middle is for Ground. put a copper wire lug on it and bolt it down onto a piece of metal that has had the paint removed around where the lug will go.
MikeMueller Posted August 10, 2011 Report Posted August 10, 2011 You may want to wire a switchable 12vlot remote wire because I have found signal sensing turn on to be a little bit iffy. I tried it on my JL before and did not like it at all. Plus it is nice to have a kill switch for when the cops are around. Mike (2 12 Type R's 1 Kac-9105D) (1 Diamond D3 12 Kac-8105d) 4 Gauge power/ground 8 Gauge Speaker wire Stock Alt Big 3 Upgrade Extra Trunk Batteries
