What size fuse should I use for the battery? Both amps are 30x3 Also what size fuses in the dist block to use?
I looked and can't find exact size fuses, for the battery there is either 150a or 200a and for the agu dist block there is either 80a or 100a
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
Use a 200A ANL fuse under the hood. Inside, use a fused distrubution block with 100 amp ANL's. Get a single 1/0 in and dual 4 gauge outs.
Edited by CleanSierra
I dunno if this helps but im running 2 amps both Rockford Fosgate 1 is t1500-1 bdcp and the other is the t600-4 and i have 1/0 from front batt to rear batt with 2 anl fuse holders at 300 amps per. 1 just before connection to each batt. then after the rear bat i used 1/0 to a 10 farad hybrid digital stinger cap. and from the cap i have 1/0 to the dis blocks(ordered a 4th anl fuse holder and a 300 amp fuse to put between the cap and the power dis block ITS NOT IN YET! WILL BE HERE WEDNESDAY). from dist blocks to amps i have 4 gauge wire with no over heating issues or anything ill get some pics up tomorrow to dark tonight(take in mind i have 3 kids im on a tight budget so my system is not even close to being done). i did use to have 4 gauge and i was melting all the plastic around the fuse holder and the plastic on the fuse it self. and when i realized this i went to disconnect it i touched the fuse holder and burned the shit out of myself lol. if you go to autotoys.com they have 1/0 stinger kits for 99 bucs shipped that should get you most of what you need then little pieces here and there
here is a direct link to the kit - http://www.autotoys.com/x/product.php?productid=11047
again i will get pics up tomarrow
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Ok thanks. I'll grab some 1/0 next time I have the money.
Alpine PDX-V9
Morel Tempo 6
Alpine SBR-S8-4
Alpine CDE 149BT
im still along way from being done its a work in progress and yes i have a prefab box till i get my custom box perfect
Edited by 01VWGREENMACHINE
BIG 3
RF T400.4
all stinger wires
  • Who's Online   0 Members, 0 Anonymous, 1597 Guests (See full list)
