need help on 0 guage install
TEX_THUMPER
If it is like the 97 I ran it under the passenger side through the frame rail and came up under the back passenger seat.
"The strongest reason for people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government." -- (Thomas Jefferson)
They are tough. Go to pass side. Run down next to motor and above the wheel well plastic. Once you're almost horizontal under the car there is a drain plug grommet on front pass floor. Pull that grommet and run up through there. If you route correctly you can zip tie out pf the way very well. Hope this helps.
Of course silicon around after. Btw the grommet is very strange. It goes through two body plates and you'll barely see light through it. You'll have to run horizontal first then pull up through. Not easy. If it fails, drill your own hole through pass front floor and seal it. Same concept. The firewall itself doesn't have many safe options.
  • Who's Online   0 Members, 0 Anonymous, 1164 Guests (See full list)
