taylorpro Posted August 8, 2011 Report Posted August 8, 2011 this is just something i came up with pretty quick. talked to a few people and the specs seem good as far as volume and tuning and all. just looking to see if you guys would suggest any additional 45's or removal of some, or added bracing and stuff like that. im going to do a little 3" or so divider vertically between the subs to keep everything on its respective side, but forgot to add it in the rendering. all opinions welcome. 1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
RAM_Designs Posted August 8, 2011 Report Posted August 8, 2011 I assume this is for a pair of 15's. In that case, I would only do a single 8" port if it had flared ends. Ryan Miskin - owner of RAM Designs I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script> 2200+ designs since March 2011...
taylorpro Posted August 9, 2011 Author Report Posted August 9, 2011 I assume this is for a pair of 15's. In that case, I would only do a single 8" port if it had flared ends. yes two 15's and it is setup as a single 8" aero. do you think the port being so short would cause any loading issues since part of the cone(s) would be over top of the end of the port? 1999 Ford ExplorerTeam Sundown Audio4th 2012 Db Drag WF Street Stock 150.8dbYoutube Channel!http://www.youtube.com/user/BoomyurblownOperation 156 No wall Build Log!http://www.stevemead...x/#entry2196123
