LoudBurp Posted August 13, 2011 Author Report Posted August 13, 2011 I would not suggest building the enclosure with the port only 2.25" from the back wall. I'd try to keep it 5.5" away. I can't comment on the rear deck as I've never messed with one. Ya I was thinking the same thing but, there lies my delema. Should I shorten the port and raise tuning, pull the port out 3 inches and not be able to close the armrest, or try to make it go through where the factory sub is.......... AAAAAAAAAAAHHHHHHHHHHHHHHH trying to make it look good while keeping it loud SUCKS!!!!!!!!! Quote Best of Luck and Cheers! There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
LoudBurp Posted August 13, 2011 Author Report Posted August 13, 2011 O and I guess I should add in that I chose to go with American Bass XFL-12's because I can get them for a better price than the AQ SC2.5-12's Quote Best of Luck and Cheers! There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
Ray Posted August 13, 2011 Report Posted August 13, 2011 Horrible design imo. Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
Ray Posted August 13, 2011 Report Posted August 13, 2011 You need to find more room. Bigger box. Subs back, port forward doesnt really work in a trunk. Id rather see 3.6 after with 12sqin per ft tuned to 35 with everything firing back. Keep it simple Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
LoudBurp Posted August 13, 2011 Author Report Posted August 13, 2011 You need to find more room. Bigger box. Subs back, port forward doesnt really work in a trunk. Id rather see 3.6 after with 12sqin per ft tuned to 35 with everything firing back. Keep it simple First, Ray thanks for taking a look. Your input means a lot seeing as, well, your the pro. Also, I was thinking that the port forward was kind of a bad idea in the beginning due to the fact that the 2 waves would never really interact w/ one another. Thanks for the confirmation. I won't even bother putting up the SketchUp of the new design, seeing as it's going to look like another ordinary box. Quote Best of Luck and Cheers! There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
