I am doing a build for one of my buddys. We are going to deciding between 2 Sundown SA-12's or 2 AQ SD2.5-12's. They will be powered by a Sundown 1500D @ 1 Ohm. This is the box I came up with and was wondering if you guys had any advise on improving it.
The top baffle will actually be cut to fit the sides of the trunk but I figured I would put it on there. The port is 15"s long and the reason why it sticks out like that is to meet up with a hole that is behind the backseat armrest, as you will see in the photos below. Also, when I do build it the port will be rounded off on the sides and where it goes between the seats will have a flare and be molded into the back seat.
Here are the pictures of the car...
If you want to make improvements, I uploaded the Sketchup file here...
http://www.mediafire.com/?b0q8qnexp6mshh3
Thanks for looking and look forward to hearing from you all
Edited by LoudBurp
Best of Luck and Cheers!
There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
Bump for input by others
more port area id say around 12 per cube
Edited by new guy
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
Thats the problem, for the port to come in between the seats like that, that is the biggest port I can run. The hole is almost exactly 8x7 which leaves the inside dimensions at 6.5x5.5. That roughly 8"^2 per cube. I normally run around 12 per, but this one is giving me issues. So, do you think I should shrink the box a little?
Edited by LoudBurp
A 6" aeroport or 3 4" aeros may work well and allow you to port where you want. Just a thought...
Why not use aeroports and port through the rear deck?
I was thinking of aeros, but I don't know how long they would have to be.
I think the 6" would have to be sticking in the box like the port I have drawn up, and I have no idea how I would make that work. Although 2 4" might work. Let me play around with it and I will see what I can do.
Thanks for the feedback!
So I was a retard when I posted the last box pics. I forgot that I resized the port for tuning. I resized it to the max allowable size and the port is now 22 inchs long. The only problem I can foresee is that the back of the port is 2.25" away from the back of the baffle. Do you think this could be a problem? Here is the Torres and SketchUps. Let me know what you think.
The SketchUp file is here...
http://www.mediafire.com/?m08njqm13j143b5
Edited by LoudBurp
..... port through the rear deck?
So I measured it out through the rear deck and I could make the port 9x9 which is 7.5x7.5 and it would have to be like 22-26 inchs long which means I would have to put a bend in it. So, I am stuck. Should I do it like I have in the pics I posted on my last post(where the port is 2.25" away from the baffle)? Or should I run it through the rear deck by take out the factory sub?
Any opinions?
(I work all weekend, so I won't be able to post a SketchUp of what the rear deck port would look like till Monday....sorry)
I would not suggest building the enclosure with the port only 2.25" from the back wall. I'd try to keep it 5.5" away.
I can't comment on the rear deck as I've never messed with one.
