4ch + 16V = ??
woodzyspl
well basically. are there any 4 channel amps that will take 16 volts? seeing sub amp is at 16 thought i should ask before i try anything lol. are there any available ect. was thinking maybe dc 174.4 but yeh lol
AUSTRALIA do i need say more?
HU: some crap pionee
AMP: dc 9k @ 18v
SUB: 4 elevation audio sqx 12"
Battery: 2 neuton power 8200d
burp setup for fun 152's
soon to come: rebuilt soundstream xxx (2 18" OR 3 15" wall) Bunch speakers, more batts and new HU
Anytime I talk to Matt at Mechman, he's always encouraging me to run 14 volt batteries and says it wont harm the stereo equipment, but make it perform better. So I'd assume any of your top quality brands should do. I'd personally look into the new T800-4AD.
1994 Cadillac Fleetwood Brougham
Pioneer AVH-P5200BT
Hertz Mille MLK-165 Component System
Hertz Hi Energy HCX-165, 6.5
Hertz Hi Energy HCX-690 (6x9s)
Audison Voce AV K6 Component System
Audison VRX 4.300
Audison VRX 2.250
Sundown 4500D
SMD 15"
XS Power D3400 (under hood) Three XS Power D3100 (trunk)
Monster XLN-201 RCAs
DC Power Engineering 390XP H/O Alternator
Remember if your running 16v your charging at 18+volts imo to high for any highs amp. I run 14v batts and charge as high as 16.8 and run 2 zapco 750.2s for my highs I had my amp guy go through them then bench test them and he was able to safely play them with up to 18v. He said the main concern would be swelling the capacitors in the amp which could cause them to blow or leak.
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
i see. my batts float at 17volts lol so yeh bit worried to try it. hmm wonder if dc could build one to take 16v..
AMP: dc 9k @ 18v
  • Who's Online   0 Members, 0 Anonymous, 886 Guests (See full list)
