The alt will charge multiple batteries and you hook up multiple batteries + to + and - to - in parallel.
Depends, is your stock battery sealed or vented? Is your stock battery location actually inside your vehicle? If the battery is vented DO NOT put them in your vehicle. Doing so will expose you to gasses that can kill you when you breathe them in and you cant smell the gas either from what ive been told.
The main stock battery is close to the engine outside of the car. it is vented more then likely
DO NOT put that in your car. Buy a battery that is AGM or sealed-maintenance free.
yes, kinetik is a sealed battery so you will be perfectly fine. That battery wont kill you but your stock one will. lol.
my issue was whether or not i even needed to use a battery isolator or not. what do you car guys mostly use? better yet, where would i put it at?
