ok thats what i was wondering. which is a better? battery to battery and no chassis involved? so its wired wire now to get a higher voltage? if it is, im only seeing 14.5. shouldnt it be higher then?
the best ground will ALWAYS be directly back to the battery
if u have have + of one battery connected to the - of the other battery ur voltage should be around 26-29 volts...if u have it + to + thats where the voltage should be
