adding a battery
There are many ways to do it.. the easiest way I've found is to run a power wire from your positive (+) under your hood to the back of your car where you can place the battery and put it on that positive (+) then take another piece and ground (-) it to the frame in the back.
You can then run power and ground straight off of that battery to your amp(s) and it will run off of both batteries.
Hummer H2
(8) Crossfire XS V2 15's
(4) Crescendo Audio BC 5500s
(16) Crescendo 6.5's, (16) Crescendo Tweeters, (4) Beyma 8" Midrange
http://www.youtube.com/Owners1
What are your system specs? Amp? Generally if you have bad voltage drop, you should add a second battery and do the big 3, it never hurts to even add another battery for even the littlest system, can never have enough power.
2x sundown audio sa 12's
Crescendo BC2000
kinetik 1800, 1400.
Rockford punch 5,25 component set
MB QUART ONYX 4.80
Mechman 270a alt
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
  • Who's Online   0 Members, 0 Anonymous, 1394 Guests (See full list)
