this is cheap and shipping is cheap too
Edit: oops wrong one. thats CCA
heres the OFC
Edited by D-train-13k
The IrishmanDCSig.jpgCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters
2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000
4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
2 runs of cca would work just as good.
but i feel ya. moneys tight these days
enough to support 2 Audioque 2200d's strapped at 1 ohm? they normally pull what 400 amps together strapped worse case scenerio at 2 ohms strapped and I'm at 1 ohm .5 per amp. So maybe worst case scenario 450 amps on cca wire that's rated to handle 250 amps.
itd be better than just 1 run. if you cant get the money together now. itll at least buy you some time until you can purchase 1/0 OFC
or try this company. i dont have any experience with them but i was recomended it from someone on here OFC welding
what is the difference between ofc and cca? not to be dumb but i rlly don kno
OFC is 100% copper.
CCA is copper clad aluminum. it's not a strong as OFC power handling wise. but its basically wire on a budget.
however KNu koncepts makes their wire slightly bigger to offer better current handling on their CCA
it depends on your demand for electricity whether or not CCA will work for you
OFC is 100% copper.
whats like the maximum waatage of power that would be good for cca?
95 toyota corolla
1.8 dohc
5 speed
system in planing stages right now
  • Who's Online   0 Members, 0 Anonymous, 1118 Guests (See full list)
