O and dont turn your head unit all the way up, dont use loud on hu if it has it, dont turn the bass on hu all the way up. Really you should find someone on to help you with all your settings so you dont have problems with clipping.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
It wont hurt them if you set your gains right and arent clipping. If it make you more comfortable to do 2ohms by all means do it.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
The subs are D4, so they'll wire down to 1ohm. The amp will do around 750 at 12v, the 1kw rating is at 14.4v.
As mentioned you won't necesarilly need full power from the amp which can be a good thing, but I'm betting the subs will take full power.
I run 3x RMS on my HDC's with no problems and have run 900watts daily on the SDC2.5's.
ok cuz then they would both be 500 and its only cuz im new to car audio and do u no were i can find a diagram to wire them
POS from each sub to the amp, NEG from each sub to the amp. That is wiring in PARALLEL
the12volt.com
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   0 Members, 0 Anonymous, 1379 Guests (See full list)
