so i have a 2001 silverado with an escalade front end
i was looking into getting hids for it but i have a question
how would the hid kit work if escalades have 1 mainplug into the headlight
the bulbs are all routed to that one plug
how would i get the kit to work?
2 jl audio 12w3's sealed
soon to be 4 level 3 15's
blow through
all dc audio
the HID kits come with ballasts that power the things. They have bulbs that plug into the stock harness.
*Edit: A kit like this:http://www.sonicelectronix.com/item_37581_Vision-Extreme-9006-6K-VE.html
Edited by CleanSierra
so how would i do it if i had a kit for the highs too?
Get two kits...
no, the headlight has one plug on the housing for all the bulbs
its not a seperate socket for the lows and highs
blow through
all dc audio
I just looked up bulbs for it and found that the High beam is the 9005 and low beam is the 9006, JUST like my 03 GMC Fullsize.
yea the 2 bulbs are wired to 1 socket.
DC.jpgDC POWER
oh man im all confused
ill be posting a pic shortly so you can understand what im talking about
blow through
all dc audio
Yeah go ahead and do that. Just take the bulb out and look at it and see what number is on it. That will tell you what model the bulb is, so THEN you can figure out what you need for an HID kit.
i know what number the bulbs are
the 2 bulbs are routed to one socket though so how would i wire up 2 kits?
blow through
all dc audio
