Guest MegaloManiac Posted November 3, 2007 Report Share Posted November 3, 2007 I would think the KNu blocks would work, since there Kollasus wire is practically 2/0awg. anybody know for sure? Quote Link to comment Share on other sites More sharing options...
WalledGMC99 Posted April 28, 2020 Report Share Posted April 28, 2020 can anyone comment on this question now? 13 years later when there are a lot of amps that have 2/0 inputs...i.e. Taramps BASS 15K Quote Link to comment Share on other sites More sharing options...
ehall8702 Posted April 30, 2020 Report Share Posted April 30, 2020 On 10/28/2007 at 10:04 PM, westvan_dude said: Run into a bit of difficulty.... installing an Autotek MM4000.1D amplifier in my super duty pickup. Going 2/0 gauge from the battery to behind the back seat close to the amplifier. The amp takes twin #2 gauge positive inputs and has twin #2 gauge gnd connections. I've looked around for distribution blocks that take 2/0 input but also have 2/0 output. Can't seem to find any. Any suggestions? Otherwise I'm just going to terminate all cables in copper eyes and run a bolt through them all. Kinda ugly though. Try these, cheap and do the job, use any size in/out you want too https://www.ebay.com/itm/171420622015 I used two of em look decent and work well. Quote 2009 Silverado 1500, 7.5" lift, 37x12.50r17s, Built Gen 4 5.3L ( 4.8l flat pistons, decked 243s, SS2 Cam, Pac 1218 springs, ported intake, 120mm TB, Long tubes, 3" duals HP tuner software tuned by me), 4l80e swapped and 4.56 gears. All done by me. stereo is Pioneer avh 600ex, all stinger rca, jp23 v1.5, skar rp150.4, and hertz hpd4. 2 SHCA 6.5 8ohm, 1 SHCA 3.5", and 1 DS18 tw120pro in each door. The 3.5 mid and 3.5" tweeters are powered by the skar rp150.4, the 6.5s are powered by the hertz bridged @4 ohms. Dual runs of 3/0 welding cable, 300a alternator, 2 Vmax AGMs up front. current sub is a AB XR 12 ( dual 2 ohm) with bottom spider cut out in 2.25 cubes at 32hz Link to comment Share on other sites More sharing options...
