never heard of an isolater or batteries killing eachother haha. If you wire them the way I told you, you should be fine. +to+ -to- I do recommend upgrading the ground from the stock battery like I said. Grounds are important.
so going + to + and - to - its a better option then grounding the battery in the back or is it just for preference?
Edited by Stephen_og
Team NWSPLUPCOMING BUILD (when I afford it)
2013 Ford Focus Hatch
2x DC lv3 15s
2x b2 quotas
XS batts
DC power alt
That amp would fuck the shit out of those subs. It would roofie them, knock them out with chloroform, then make sweet, gentle, anal love to them all night.
As far as the killing your battery thing goes... That is in regards to you running an AGM in the back and your stock up front. Regular old batteries sit around 12.4-12.6 volts as to where AGMs sit around 12.9+ which means that your AGM will be constantly trying to equal out the other battery, but it can't.
Unless you are going over 2kw you can just use one good battery up front.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
Yeah, Soon i will be getting another cadence F1200-1D to run as a slave and at that point is when I will be adding another battery. there 1200RMS at 1 ohm but right now I am only going to be running the one I will be getting in a couple days at 2 ohms which is 760 RMS, and plus once I get the DC level 4 12's im wanting to get, I will be running two of the cadence amps at 1 ohm.
2x DC lv3 15s
2x b2 quotas
XS batts
DC power alt
That actually brings up another question of mine, when you add a slave amp to an existing amp you already have ( btw these cadence flash amps allow you to do so) does the power from the slave amp equal what you have your subwoofers wired to on the master amp?
2x DC lv3 15s
2x b2 quotas
XS batts
DC power alt
If your amp is say 1200 watts at 1ohm then when you strap them (master/slave) you need to provide a 2ohm load to the pair.
Pioneer X8500
Second Skin
2 270a Mechman Alts
  • 1 month later...
Glad SOMEONE knew what I was talking about. It's not mandatory but it helps
06 Chrysler 300
Pioneer avh-x8500bhs
Hertz Hsk 130.4
Alpine mrp-F600
2 Dc level 4 12s
Dc 2k
Viper 5901
SHCA wiring
KnuKonceptz RCA's
SecondSkin/Fatmat
Big 3-stock alt
  • Who's Online   0 Members, 0 Anonymous, 2595 Guests (See full list)
