NYC54 Posted August 25, 2011 Report Posted August 25, 2011 ok so im new to box building , i have a few questions , i have a 1992 cadillac brougham , i wanted to put 1 12 inch re audio xxx but i want it inverted , also i want to fiberglass the floor to use as the box floor , will this work ? here are some pics to get an idea of what im trying to say , sorry for the crappy pics
adam6604 Posted August 25, 2011 Report Posted August 25, 2011 Yeah as long as it's completely sealed looks like it would work. Just build it strong and lots of glass it should be fine but let the pros answer this haha Driving my 2008 Dodge Ram 2500 MEGA cab with the 5.7 hemi. Audio: Two 10" Alpine Type R's ( 1000rms models ) Hifonics BRZ 2400.1D @ .5 ohm Two Kinetic 1400 batteries ( soon to have XS power under hood ) Tsunami 1/0 Awg wire throughout truck. Stock Infinity 7 speaker system ( Junk ) soon to be replaced, probably all Alpine. Exterior: 17"Dick cepek rims with 33" Toyo MT tires Bushwacker fender flares Magnaflow true duel exhaust LED tail lights with Projector headlights Plasti-dip fun coming soon!
NYC54 Posted August 25, 2011 Author Report Posted August 25, 2011 Thanks for the response , how do I calculate that weird angle ?
NYC54 Posted August 26, 2011 Author Report Posted August 26, 2011 Thanks for the response , how do I calculate that weird angle ? Anyone?
bumonskateboard6 Posted August 28, 2011 Report Posted August 28, 2011 Get an angle finder to figure out that angle, also be sure to check the volume of the area you plan to glass. Current Systems: 2011 BMW 335i Hertz HDP1 DC LVL3 12" Full Carbon Fiber 2002 Acura TlKenwood DNX9980HD2 DCLVL4 12" Subs with LVL5 Parts D.7 CoilsDC 3.5kHertz HSK-165 up front HCX-165 RearHertz HDP4 AmpDC Power Engineering 260 Amp AltBig 3 and amp powered with KNU 1/0XS Power D2400 Up Front i pulled out my dick in class many of times and had it shown. get over it bitch...stupid open legged hairy beavered bitch... going over rms = smaller box, under rms = bigger box... Low voltage doesn't blow amps. That's a myth. A router that does the sub holes makes rounded edges also?
Quiet Posted August 30, 2011 Report Posted August 30, 2011 Measure as close as you can, and guestimate + or - . If you're building sealed, you'll be ok being off If you're building ported, find a way to make your port adjustable, or make removable square ports in different lengths and see which one you like best. also, I wouldn't seal it all the way up to the bottom of the rear deck, or else you might not get enough sound in the cabin. can't wait to see what you come up with. 2007 Pacifica Rebuild. Less quiet. Still not loud.
