Front Stage Speaker Placement
What would you do?
My factory door setup has the speakers placed off axis;
I'm adding another component system, so would you..
Place the second 6.5 in the door, in this open spot to the left;
with the tweeter in the A-pillar? (said tweeter placement is not definite);
Or would you build a box for the new component system and mount it in this center column;
Kinda like my boy Total Mayhem has in his Tahoe;
Or would you do kick panels?
The plus to simply making a baffle for that open spot in my door is less money, and simple installation.
The negative to placing the mid bass driver there is it's too close to the seat.
The plus to the center column setup is the staging and imaging would be illuminated when combined with my current setup.
The negative is simply the time I'll have to take to build a box (and the extra money). I guess the same could be said for kick panels..
The placement that I choose must also accommodate for a mid range speaker in the near future..
So, what's your opinion?
1994 Cadillac Fleetwood Brougham
Pioneer AVH-P5200BT
Hertz Mille MLK-165 Component System
Hertz Hi Energy HCX-165, 6.5
Hertz Hi Energy HCX-690 (6x9s)
Audison Voce AV K6 Component System
Audison VRX 4.300
Audison VRX 2.250
Sundown 4500D
SMD 15"
XS Power D3400 (under hood) Three XS Power D3100 (trunk)
Monster XLN-201 RCAs
DC Power Engineering 390XP H/O Alternator
IMO if you're after pure SQ you can't beat kickpanels.
I don't get the console speaker idea unless you have major SPL and just need more mid/highs to keep up, but maybe that's just me (I did see those were Hertz comps in those pics, but the placement??)
Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R
DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz
Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage
Silver Flute 8" midbass in doors powered by Alpine 3539
Alpine CDA-117 HU
You're right, the person with the Hertz built on that center hump had major SPL (Warhorse with 2 SMD 18s).
Kick panels were actually my last resort, but I might try it.
Pioneer AVH-P5200BT
Audison VRX 4.300
Audison VRX 2.250
Sundown 4500D
SMD 15"
  • 4 weeks later...
I would deaden the doors first ... then reinstall the drivers (or new drivers) ...
then install the tweeters high up on the A-pillars (eye level) ... use external cups to set up for proper listening for stage and image ...
This is what I would do First before any major modification is done ... you might like the outcome ...
the last pages of my build log shows my door installations ... please check it out ... click the link on my Signature ...
thanks, Randal ...
Edited by Cablguy184
  • Who's Online   1 Member, 0 Anonymous, 1084 Guests (See full list)
