EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 wait wait am i reading this right you took off the cat and put on a glasspack in its place?? if thats so then that is your problem. your truck is an 01 which means that its obdII. which means that there should be a pre cat and an after cat o2 sensor. since you took off the cat the after cat isnt seeing the right info which is making your truck run wayyyy rich which is making it bog down and backfire because the engine is getting way too much fuel. put a cat back on your truck and that should fix the problem. I have a 2001-s10 truck and i cut out the cats and put pipe there and just put the o2-sensor back in the pipe and i have no code and it runs better than ever, when my truck was runing like that ended up puting fuelpump in it and changeing the pluges thay where fouled out, any way you do not have to have a cat on the truck 4it 2run right, so the fuel pump and plugs was your problem?
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 What's ur name on there lol thats were I am most of the time sdime0921 lol
CHEVY4X4BLAZER Posted August 27, 2011 Report Posted August 27, 2011 Check your MAP sensor. If you haven't checked the fuel tank you could have a clogged fuel pump screen.
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 Check your MAP sensor. If you haven't checked the fuel tank you could have a clogged fuel pump screen. where is that sensor??
CHEVY4X4BLAZER Posted August 27, 2011 Report Posted August 27, 2011 On my 91 its to the left of the TBI. there is a wire plug and a vacuum line on it
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 On my 91 its to the left of the TBI. there is a wire plug and a vacuum line on it alright thanks man
CHEVY4X4BLAZER Posted August 27, 2011 Report Posted August 27, 2011 My fuel tank had a screen that was clogged and once it warmed up it would get sucked into the pump. Then I had the performance problems like mis firing and bog down
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 My fuel tank had a screen that was clogged and once it warmed up it would get sucked into the pump. Then I had the performance problems like mis firing and bog down how do you get to that screen?
mylows10 Posted August 27, 2011 Report Posted August 27, 2011 My fuel tank had a screen that was clogged and once it warmed up it would get sucked into the pump. Then I had the performance problems like mis firing and bog down how do you get to that screen? its in the tank,also check the egr valve might be stuck open a little dc 12k 2 ascendant mayhem 12s xs power 200 amp alt 2 odyessy pc 2150 dc audio 175 x 4 scosche wires stinger inter connects 12 volt customs 175 amp alt pioneer avhp 4100 dvd arc audio eq cdt 6.5 components 152.8 db drag street c http://www.dcsoundlab.com/ //www.dcsoundlab.com/images/header.jpg
EvanSpurlock Posted August 27, 2011 Author Report Posted August 27, 2011 My fuel tank had a screen that was clogged and once it warmed up it would get sucked into the pump. Then I had the performance problems like mis firing and bog down how do you get to that screen? its in the tank,also check the egr valve might be stuck open a little alright man i appreciate the help
