AJ8B6V Posted August 27, 2011 Report Posted August 27, 2011 Hi i need help in converting my 98 Chevy work truck to a 98 Silverado for better looks. Im looking for someone with all the parts or a website with the conversion kit. Here are some pics of my current setup and how i want it to look. Im using pics off google not actual pics of my truck.
dtleonard26 Posted August 27, 2011 Report Posted August 27, 2011 Godfather customs has a grill and light combo not sure how much they run though Bagged 83 C10 89 K1500
theTank77 Posted August 27, 2011 Report Posted August 27, 2011 Hi i need help in converting my 98 Chevy work truck to a 98 Silverado for better looks. Im looking for someone with all the parts or a website with the conversion kit. Here are some pics of my current setup and how i want it to look. Im using pics off google not actual pics of my truck. the only difference is the grill, headlights, and blinkers. you can order some cheap crystal headlights and blinkers off ebay and just go to a junkyard for a grill. everything will bolt right on. if you want to save yourself some trouble go get a haynes manual. itll show you how to do it. the only thing that youll need to have done is you need to get the headlights aimed after installing if you dont know how to properly do it yourself. get some crystal headlight housings with some HIDs and some led blinker bulbs and youll be set my build log
AJ8B6V Posted August 27, 2011 Author Report Posted August 27, 2011 Hi i need help in converting my 98 Chevy work truck to a 98 Silverado for better looks. Im looking for someone with all the parts or a website with the conversion kit. Here are some pics of my current setup and how i want it to look. Im using pics off google not actual pics of my truck. the only difference is the grill, headlights, and blinkers. you can order some cheap crystal headlights and blinkers off ebay and just go to a junkyard for a grill. everything will bolt right on. if you want to save yourself some trouble go get a haynes manual. itll show you how to do it. the only thing that youll need to have done is you need to get the headlights aimed after installing if you dont know how to properly do it yourself. get some crystal headlight housings with some HIDs and some led blinker bulbs and youll be set Does my current Bumber stay the same?
theTank77 Posted August 27, 2011 Report Posted August 27, 2011 headlights and blinkers - http://cgi.ebay.com/ebaymotors/94-98-Silverado-Chrome-Housing-Headlights-Bumper-Corner-/300591672873?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1998|Submodel%3ASilverado&hash=item45fca8ee29 Grill- http://cgi.ebay.com/ebaymotors/CAR-EMBLEM-PROVISION-NEW-BAR-Grille-Assembly-Grill-/320743434941?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A1998|Submodel%3ASilverado&hash=item4aadcc6abd HID kit for low beams - http://cgi.ebay.com/ebaymotors/Ultra-Slim-HID-Xenon-Conversion-Kit-9006-HB4-6000K-/120756987756?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c1dad676c these are 6000k which are pure white if you want blue ones go with a higher temp High beam bulbs - http://cgi.ebay.com/ebaymotors/9005-HB3-White-HID-6000K-Xenon-Bulb-Headlight-Lamp-100W-/370531989369?pt=Motors_Car_Truck_Parts_Accessories&hash=item56456d7779 my build log
AJ8B6V Posted August 27, 2011 Author Report Posted August 27, 2011 headlights and blinkers - http://cgi.ebay.com/...=item45fca8ee29 Grill- http://cgi.ebay.com/...=item4aadcc6abd HID kit for low beams - http://cgi.ebay.com/...=item1c1dad676c these are 6000k which are pure white if you want blue ones go with a higher temp High beam bulbs - http://cgi.ebay.com/...=item56456d7779 Thanks Bro. This helps alot.
theTank77 Posted August 27, 2011 Report Posted August 27, 2011 yep the bumper is the same. you will also need to change the wireing for your headlights because you are going to be converting them from h4 bulbs to 9006 bulbs for the low beam and 9005 bulbs for the high beam which you can purchase the new plugs at any auto store. i put up a post for everything else youll need my build log
theTank77 Posted August 27, 2011 Report Posted August 27, 2011 i think total itll cost you around $210-$250 not including getting your headlights aimed. and about 2-3 hours of work depending on how quick you are and how good you are with wiring. my build log
CleanSierra Posted August 27, 2011 Report Posted August 27, 2011 If you're gonna change out the grille and headlights, don't mess around converting it to a Silverado. Change that shit to a Sierra it's MUCH better looking with a billet grill installed. Plus headlights and side markers are the same as silverado. Also, don't even think about this upgrade before the truck is mechanically sound. Get that transmission fixed son! Im not the one you want to try to troll. Just a fyi for you.
theTank77 Posted August 27, 2011 Report Posted August 27, 2011 If you're gonna change out the grille and headlights, don't mess around converting it to a Silverado. Change that shit to a Sierra it's MUCH better looking with a billet grill installed. Plus headlights and side markers are the same as silverado. Also, don't even think about this upgrade before the truck is mechanically sound. Get that transmission fixed son! Sierra is the exact same truck except it says GMC on the grill instead of the chevy badge. and its not hard to get the billet inserts. its all the same. my build log
