It is low on the port area side however I am not completely sure how to do it on areo ports but one 4" areo 10" long should tune you around should tune you to ~35.11hz using Torres calculator. If you can get one wth flares on both ends
edit: This port and before you seal it solid you can test different lengths and see if it is sounding right to you but I would start at 10" long
That's the one I was looking at. Does the port have to be in a certain location in the box or can I have it on the side?
as long as it is ~4-6" from any wall or obstruction it should work just fine on the side. just make sure you have clearance from the sub inside also when you determine the exact location
I'm having serious reservations about the port length variations... but if you really wanted to do that, I would suggest adding the same slant to the other end of the port to match. That should get rid of any issues with the port length variances. Maybe. :shrug:
I wonder if Ray would chime in on this thread...
2007 Pacifica
thought about putting the port on the bottom of the box coming out the side like some of the Boston acoustics do and i believe some kicker prefabs did it as well that would fix all your issues
Build in progress
Alpine CDEHD-138BT
Alpine SPX-17PRO 2x
Alpine SWS-15d2 2x
Alpine PDX-V9 2x
Alpine PDX-M12
Stinger SPC5050
Stinger 1/0ga and 4ga
Audioquest interconnects and Speaker wire
Dynomat 10455 mega bulk pak
Dynomat 1/8 and 1/4 liner
All that in a Reg cab truck and it wont be a blow though
  • Who's Online   0 Members, 0 Anonymous, 3366 Guests (See full list)
