Witch is my remote wire in my car??
1998 Acura CL Stereo Wiring
Constant 12V+ Blue/White
Switched 12V+ Yellow/Red
Ground Black
Illumination Red/Black
Dimmer n/a
Antenna Trigger n/a
Antenna Rear Window
Front Speakers 5 1/4" Doors
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Front (+) Red/Green
Right Front (-) Brown/Black
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Please help i just bought 2 lanzar 1000 watt amps
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Rear Window
I'd use the Switched 12V+ Yellow/Red Connection. That wire turns on your head unit when you turn the key, and if you tap into that..it will turn on your amps as well. Someone correct me if that's wrong..but that's what I'd do.
First System
2002 Impala LS 3.8L V6, 128,365k miles.
Alternator: DC Power 190Amp H/O Alternator
Headunit: Kenwood KDC-BT945U.
Speakers: MBQuart 6.5" Comps, 6x9 3-way.
Amplifer: Eclipse 3322 on front 6.5 components, and a Infinity Kappa One @ 2ohm- 800w
Subwoofers: 2 REAudio SRX12D2 wired to 2 ohm.
Box: 3.1cuft box tuned to 33hz. sealed off to cabin
Big 3- done with all Knukonceptz KCA 0 gauge.
Don't drop below 14.1v at full tilt. :)
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Rear Window
this line is your remote for your amp
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Rear Window
Alight thanks so much
Ground Black
Dimmer n/a
Antenna Trigger n/a
Antenna Rear Window
When i hook my remote wire up do i tie it in with the radio and the original wire also? like all 3 wires?
witch=scary woman that rides a broom
which is the version fo the word you are looking for :)
I was just being funny, or trying anyway.
oh well i have speech problems but when i split the remote wire from the radio connected to the harness do i split both ends of that wire and tie them in with my amp remote wire?
  • Who's Online   0 Members, 0 Anonymous, 709 Guests (See full list)
