SPL Dynamics ICE-3500d or Hifonics Brutus BRZ 2400.1d
Hello everyone.
Thanks for reading my topic. I would like to have some help in choosing between the two mono amps below,
SPL Dynamics ICE-3500d (300Amps FUSE)
Max Power: 8000W
RMS Power Rating (@ 14.4V):
RMS @ 4OHM : 700W x 1 chan.
RMS @ 2OHM : 1500W x 1 chan.
RMS @ 1OHM : 2500W x 1 chan.
RMS @ 0.5OHM : 3500W 0,15%thd x 1 chan.
RMS @ 0,5OHM : 4000W 1%thd x 1 chan.
VS...
Hifonics Brutus BRZ 2400.1d (250Amps FUSE)
4 ohms: 850 watts x 1 chan.
2 ohms: 1700 watts x 1 chan.
1 ohm: 2400 watts x 1 chan.
Probably both of them are good amps but which would I choose between the two?
I want to run my Orion HCCA 15.2 the best way possible.
Please help me choose.
Thank you in advance.
LET THERE BE BASS...!
What do you think about that?
Ampire MBX3000.1 mono amplifier with 3000 watts RMS @ 1 Ohm
Ampire MBX3000.1
Quick Overview
What's behind it, tuning and sound when competitions are won in the high decibel range? In general, a unique combination of amplifiers and subwoofers. Reasons why so many tuning professionals and amateurs for the tuning of the amplifier and subwoofer Ampire. The amplifiers make excellent, distortion-free power and superior quality in the car and is compact and easy to install.
Technical data
digital Class D mono amplifier
1 ohm stable
1x 1130 watts RMS into 4 ohms @ 14.4 VDC
1x 2030 watts RMS @ 2 ohms 14.4 volts
1x 3000 watts RMS at 1 Ohm @ 14,4 Volt
1x 5000 watts max. @ 1 ohm 14.4 volts
Frequency Response 15 - 300Hz.
Low-pass crossover 30 - 300Hz.
Low Pass Slope 24dB
Subsonic filter 15-35Hz
Bass Boost @ 40Hz 0-10dB
Phase adjustment 0 / 180 °
Input Sensitivity 200mV-9, 0V
Input impedance 20kOhm
Signal to Noise Ratio> 100dB
Distortion: <0.5%
Damping factor of 300
massive block terminals
350A ANL fuse
Weight 8 kg
dimensions 254x64x565mm
Bass level remote control
I THINK THAT THAT IS THE BEST....
AND ITS VALUE ITS BETWEEN THE OTHER TWO (HIFONICS AND SPL DYNAMICS)
TELL ME YOUR THOUGHTS
:( Soundstream. I woulda went with the SPL D
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I woulda done spl also. Lol.
Sup n8??
que? same as always ray. you know im not a fan of soundstream. they aint the same no more
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
I like wiring down as low as possible to keep rise to a min.
Xxx6500 has so many issues its not even funny
  • Who's Online   1 Member, 0 Anonymous, 1498 Guests (See full list)
